HP DesignJet 3500 Color change language
  • bojans
    • 1313
    HI,
    This machine is new, but wasn't working. I have changed carriage belt on this machine, cause it was rot.
    Now it's performing adjustment, but seems that printheads are not good, too.
    BUt my problem is German language. Is there option to change it to English through Menu or have to change firmware?
    Thank you very much
  • drvett82
    • Dec 2012
    • 24
    Re: HP DesignJet 3500 Color change language
    DJ 3000,3500,3800 User Guide.pdf In the user manual under HP- GL/@ configuration print. you csn down load the user manual onn line.
    • bojans
      • 1313
      Originally posted by drvett82
      [ATTACH=CONFIG]19300[/ATTACH] In the user manual under HP- GL/@ configuration print. you csn down load the user manual onn line.
      Thanks mate,
      Figured how to change language.
      Still waiting for printheads to install printer.
      • JustManuals
        • Jan 2006
        • 9838
        If all else fails.............RTFM
