HP p4015 error 51.20
  • Lbcoaster
    • 43
    [Error Code] HP p4015 error 51.20
    Had a Hp p4015 with a 51.20 error code, replaced laser scanner lasted for just over a month and 51.20 is back, very reluctant to replace the DC controller not sure this would or could burn out another scanner unit?
    Any help is appreciated.
    Steve
  • Wild Bill
    • Jul 2005
    • 774
    Re: HP p4015 error 51.20
    #1.) Did you update firmware so we can eliminate that?
    1. From the DIAGNOSTICS menu, run the
    laser/scanner motor component test.
    Verify that you can hear motor rotate.
    2. If you cannot hear the motor rotate,
    verify that the connections to connector
    J86 and connector J93 on the DC
    controller PCA are firmly seated.
    3. Verify that the wiring harness at the
    laser/scanner assembly is securely
    attached.
    4. If the error persists, replace the laser/
    scanner assembly.
    Izzy
    • Lbcoaster
      • 43
      Thanks I will give those a try...
      • Lbcoaster
        • 43
        I did have to replace the laser unit, thanks for the help...
        • prntrfxr
          • 1622
          This is a weakness with these machines. Expect more replacements than usual.
          • JustManuals
            • Jan 2006
            • 9838
            Paul@justmanuals.com
