Error 59.2:00 HP Designjet T790
  • fbkhan3
    • May 2012
    • 421
    [Error Code] Error 59.2:00 HP Designjet T790
    hi,hope you doing great guys.
    wanted to have your expert opinion regarding this issue,it's 59.2:00 i have tried new formattor but still same thing,trying to flash firmware(IG_03_00_04_2-INCR-MS_01_01_23_1.fmw)is it the correct one?because this is the msg (treieu la unidat flash USB)i have at the end without any luck! not able to change the language as well.
    input most wellcome
    thanks in advance!
  • fbkhan3
    • May 2012
    • 421
    Re: Error 59.2:00 HP Designjet T790
    update,changed hdd and flash new firmware (IG_03_00_04_2-INCR-MS_01_01_23_1.fmw) and bingo,it's all set now.
    thanks for reading!
