Laser Jett 1000
  • lenovos
    • Oct 2012
    • 140
    Laser Jett 1000
    I have a customer tha loves his Laser Jett 1000. The printer has no power. I replaced the mother board and still no power.
    Front door does make switch on mother board. Any other ideas would be much appreciated. Thanks, and I know the printer should be retired, but the customer seem to like it.
  • JustManuals
    • Jan 2006
    • 9838
    Re: Laser Jett 1000
    Paul@justmanuals.com
    • Iowatech
      Not a service manager
      • 3930
      Re: Laser Jett 1000
      Perhaps the power cord or it's connections are bad? They do wear out over time. Or the voltage coming out of the wall socket is wrong? Hopefully not like the worst time I encountered that and I got an uncomfortable shock the first time I touched bare metal on that machine even though the machine was off.
      • wseyller
        • Sep 2012
        • 1129
        Re: Laser Jett 1000
        You use the term motherboard which is not used by HP on this equipment. Did you change the ECU (Engine Control Unit)? Or the formatter? I assume you are referring to the ECU which also includes the low voltage power system. It is the board on the bottom of the unit in which the power cable plugs into.
        When you power on the device do you hear any fans or motors turning. Does the fuser get warm. Bad power cable or surge or outlet?
        • lenovos
          • Oct 2012
          • 140
          Re: Laser Jett 1000
          Hi you are right I replaced the ECU , swapped power cords, and checked interlocks. No motors turn and the fuser does not heat up.
          • HP:guy
            • Feb 2013
            • 279
            Re: Laser Jett 1000
            Are the fuser levers up? Motors correctly mounted? Have check the wiring for pinches?
            • lenovos
              • Oct 2012
              • 140
              Re: Laser Jett 1000
              Just to follow up I ended up replacing machine with HP 1200. Copier is now on junk pile.
