Hi , I have a problem with alignment of colors. I have already : replaced all cartridges (original), full calibrated many times, replaced image transfer kit, performed NVRAM initalization, cleaned lasers ,cleaned sensors.. Any suggestion what to do next?
HP color laserjet CP4005 alignment problem
Re: HP color laserjet CP4005 alignment problem
Paul@justmanuals.com
From the diagnostics menu, perform disable cartridge check. Move the cartridges to a different slot. Test to see if the problem follows the cartridge or stays with the slot. If it follows the cartridge, you have a defective cartridge. If it stays with the slot, check to see if the belt does the same thing in another printer (same belt will work in a 4700 or 4730mfp).
It may be the DC controller if it stays with the slot, and you've ruled out everything else.Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".Comment
