hp color laserjet CM 6030 error" 30.01.47, scanner failure" displays on the screen
  • bisiawoeyo
    • Dec 2007
    • 65
    this error comes up on this printer ,can anyone help me out on what to do to get the printer working again.This is my first time working on this printer.Any hint will be appreciated.Tanx.
    Bisi.
  • Wild Bill
    • Jul 2005
    • 774
    Re: hp color laserjet CM 6030 error" 30.01.47, scanner failure" displays on the scre
    My Service Guide goes to 30.01.46 No 47 Basically check connections, sensors then board
    30.01.46 Scanner failure
    The CPB enumeration failed.
    1. Turn the product off and then on.
    2. Check the PCI cable at the scanner and formatter.
    3. Check the SCB connections.
    4. Replace the CPB.
    Izzy
    • bisiawoeyo
      • Dec 2007
      • 65
      4. Replace the CPB.
      tanx Bill. I will try them out.
      • prntrfxr
        • 1622
        My recommendation is to get a manual for this machine. They are not like other HP machines.
        Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
        • JustManuals
          • Jan 2006
          • 9838
          Paul@justmanuals.com
          • bisiawoeyo
            • Dec 2007
            • 65
            [QUOTE=prntrfxr;364729]My recommendation is to get a manual for this machine. They are not like other HP machines.[/QUOTEtTanx I have the manual but it only has 30.01.46 and no 47. ]
            • bisiawoeyo
              • Dec 2007
              • 65
              tanx akk I have been able to rectify the fault,I had tp remove and reconnect the pci harness on the scanner and formatter.Tanx it worked.
              Bisi.
              • bisiawoeyo
                • Dec 2007
                • 65
                thanks,After rectifying this fault I suddenly discovered that the scan,email and fax icons on the display panel have disappeared,Anyone with any useful hint.Please bail out!
                Tanx in advance.
                Bisi.
                • Iowatech
                  Not a service manager
                  • 3930
                  Any chance the hard drive isn't hooked up correctly, or maybe it is kaputt?
                  • Lukee
                    I think you will find you will need to re-enter in the scan settings and the fax settings back in the machine, easiest way is through the web interface. hopefully thats all it is for you.
