Hi all. So i have this question wich i know it sounds really simple, but i can't figure out the answer. Hope some of you guys will help me with that. So i have this hp laserjet 8000dn wich prints these really tiny black dots all over the paper. I'm sure it's a cartridge problem, my guess is that the developer roller is causing this issue, but i need to know your input on this. The cartridge was rebuild, i'm sure the toner is ok. Your thoughts on this?
Tiny dots all over the paper - hp 8000dn
Re: Tiny dots all over the paper - hp 8000dn
Paul@justmanuals.com
The toner cartridge is an all in one unit (drum mag and toner) so replace it....Were you thinking of reusing the toner?
You should do a stop test' Stop print before fuser to make sure its not the fuser.IzzyComment
Usually on these HPs if you get sprinkles of toner on the page I most often find the the recovery blade is warped or worn from damage. The recovery blade is located near the wiper blade and drum. Waste toner will come out in sprinkles a lot of times. Only the good remanufactures will make sure the recovery blade is good and replace when necessary.
Sent from my Galaxy Nexus using Tapatalk 2Comment
