HP Designjet 1050c printhead faulty
  • Shayx
    • Nov 2011
    • 32
    hello.
    we have a hp designjet 1050c that we found in an abandoned offices building.
    first thing we noticed is that it had a leak of the magenta ink, we cut the tube and washed the mechanism with Alcohol.
    we also seen that the carriage belt is torn. we bought a new belt and installed- works perfect.
    the only issue remaining now is the machine keeps warning that the black printhead is faulty.
    how can i tell if it is really faulty or i have another problem? the black cleaning pad on the cleaners is missing. does it have to do with the error?
    i read online that it could also be a bad carriage assembly or air in the tube system, how can i tell which problem i'm having?
    the yellow printhead also stated faulty but after a few in and outs it is now in OK status.
    the black was at a reseat status, we cleaned the connectors with alcohol on both ends
    but it just went to faulty status.
    so what should my next step be?
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    Re: HP Designjet 1050c printhead faulty
    If the machine had been sitting unused for a while, you should assume all of the printheads are bad and replace them. If I were the tech working on it, I would have put new heads in the estimate.
    • Shayx
      • Nov 2011
      • 32
      you think?
      despite all the other printheads seems ok?
      and the leaking also returned.
      is there any way to buy only the specific magenta mechanism instead of the full tube system?
      • fixthecopier
        ALIEN OVERLORD
        • 4713
        Originally posted by Shayx
        you think?
        No, the tube system is an assembly. The seals have dry rot. When powdered up they are pressurized. The tube system is easy.
        • JustManuals
          • Jan 2006
          • 9838
          http://www.justmanuals.com/designjet-1050c1055cm-series-parts-service-manual-p-23509.html?cPath=402_407
          sher-v2-parts-service-manualpdf-p-21980.html
          Paul@justmanuals.com
          • Shayx
            • Nov 2011
            • 32
            so i need to spend 400$ because just one of the tubes is defective?
            why can't i just order this valve assembly and replace the defective one?
            Find many great new & used options and get the best deals for Q1251-60265 Designjet 1050C Ink Tube System Ink Supply Valve Assy NEW CONDITION at the best online prices at eBay! Free shipping for many products!
            about the printheads - should a set of 4 printheads be more affordable than buying just one?
            • fixthecopier
              ALIEN OVERLORD
              • 4713
              If you want to piece it together, that's your call. That plotter is around 10 to 12 years old. If it has been sitting a while, there is probably other seals damaged. Keep in mind that if you get it running and pump air bubbles into the heads, you can fuck them up. As a tech working for a paying customer, I don't want to be back a few weeks later explaining why there is blue ink all over the floor. If you had said you had been using the plotter every week for the past year, I would say change the valve. You said you found it. You don't know when it last ran. I work for the military mainly, and sometimes these are put on a plane and shipped somewhere. I can't take chances. If you plan to use it for a long time, change the whole system. That is my advice.
