HP CM6040
  • brunot
    • May 2012
    • 148
    HP CM6040
    Jamming 13.20.00,checked Fixing-delivery media-feed sensor,Paper Sensors E and F - G.
    Same problem!
    please advice
  • Lasersupplies
    • Jul 2011
    • 221
    Re: HP CM6040
    What tray are you feeding from and where is the the jam occurring?
    • brunot
      • May 2012
      • 148
      Re: HP CM6040
      there is no paper inside the printer.
      • brunot
        • May 2012
        • 148
        Re: HP CM6040
        on screen: "jam inside right door""
        • Wild Bill
          • Jul 2005
          • 774
          Re: HP CM6040
          what other errors? 13.20 just means that a paper was left at a possible 3 different locations. If it wont clear there is a tripped sensor somewhere. Paper feed, Under the toner or at fuser
          Izzy
          • brunot
            • May 2012
            • 148
            Re: HP CM6040
            Thank you i will check these sections
            • brunot
              • May 2012
              • 148
              Re: HP CM6040
              Checked all sections and cleaned all sensors:there's no paper inside the printer but at start up machine indicates error code 13.20.00 - "jam inside right door"
              Is it possible that a broken cable(sensor),can cause this problem?
              Please advice
              • Wild Bill
                • Jul 2005
                • 774
                Re: HP CM6040
                Do you have the manual? Cause there's a sensor test and also sensor location diagram in there.
                Yes there is a sensor that is either bad or made when its not supposed to be.
                Izzy
                • brunot
                  • May 2012
                  • 148
                  Re: HP CM6040
                  Yes i have the manual
                  • brunot
                    • May 2012
                    • 148
                    Re: HP CM6040
                    Latest test performed: i have disconnected all connectors related to the right door(duplex unit) but at start up the same error code is displayed 13.20.00 "jam inside right door"
                    • Iowatech
                      Not a service manager
                      • 3930
                      Re: HP CM6040
                      This might be stupid, but have you turned the machine off and unplugged it for a few minutes?
                      Also, you might try pulling all of the paper trays out before you turn the machine on, there could be a print job that tries to restart when the machine turns on but can't because of worn feed rollers or something.
                      Sorry if that was a waste of time.
