HP.Jetdirect Interface.
  • Hansoon
    • Sep 2007
    • 3376
    Is there hope to revive a Jetdirect Interface # j2552-60003 for the Designjet 750c?
    Interface is loosing sometimes connection and only occasionally answering pings.
    Hans
  • Bolivia
    • May 2010
    • 22
    Re: HP.Jetdirect Interface.
    Hans
    Nope, If you are sure it's the Jet Direct then u must replace it... Some of the older plotters are also "finicky" if you upgrade the Jet Direct so it's better to replace with same version......
