4525 ITB Reset
+ More Options
Posts
  • cscce
    • Jun 2014
    • 156
    4525 ITB Reset
    I've seen a few HP CP4525 transfer belts fail to reset the life count to 100%. If this happens the New ITB flag will be in the "tripped" position (see photo). Use the following procedure to reset the flag on the ITB so it can be reinstalled and trip the printer's "New ITB sensor" flag.
    1. Clean the New ITB sensor flag thoroughly with canned air and pull the flag toward you to make sure it swings freely. It's on the right, near the cyan drum. (see photo: ITB sensor.jpg)
    2. Use a pen or paperclip to press in the center hole on the side of the new ITB while turning the white Alienation Gear clockwise. (see photo: ITB flag reset.jpg)
    3. After a few turns the ITB reset flag will reappear. I prefer leaving it at an angle as shown rather than at 90 degrees. This minimizes the chance of accidentally tripping it.
    4. Insert the new ITB and turn power on. It should start callibrating. If it doesn't, repeat the process.
    5. Print a supply status page to verify that the ITB life is at 100%.
  • 20 year tech
    • May 2014
    • 577
    Re: 4525 ITB Reset
    great tip thanks for sharing
    • karl_frederick
      • 8
      Re: 4525 ITB Reset
      Many thanks!!!
      Thank you very much for sharing....
      • jernbec924
        Re: 4525 ITB Reset
        Great Information, Thanks.
        • qtildawn
          • Apr 2016
          • 3
          Re: 4525 ITB Reset
          Thanks, I learned something new
          • Millennium
            • 30
            Re: 4525 ITB Reset
            Apologies for resurrecting from the dead but I also wanted to thank you for this tip with the pictures attached. Saved my bacon on this fine Friday morning!
            • cscce
              • Jun 2014
              • 156
              Re: 4525 ITB Reset
              Great!
              BTW, this fix also works on the CM4540 and the CP4020 series.
              • reinaldo6588
                Re: 4525 ITB Reset
                Gracias, funciono a la perfeccion
                • Lor Nicotero
                  • Dec 2017
                  • 3
                  Re: 4525 ITB Reset
                  Thank you so much!!
                  • fredd_xpert
                    Re: 4525 ITB Reset
                    Buenos dias , sobre el post de la faja de hp cp4525 , muy agradecido quedo la solucion brindada en este foro.
