High-Voltage power supply on HP LJ M4555
  • theengel
    • Nov 2011
    • 1784
    I have to replace the High-Voltage power supply on an HP LJ M4555. Anyone ever done this? The manual doesn't have directions. Looks like I'll have to strip it down to the very base, so if anyone knows something that would help me... :>
  • Wild Bill
    • Jul 2005
    • 774
    Re: High-Voltage power supply on HP LJ M4555
    It's in there Page 204 chapter 2
    You know this thing looks just like the 4345 never did a 4555 but they are close; Gotta remove the scanner. I would replace the swingplate/fuser drive stuff
    Izzy
    • theengel
      • Nov 2011
      • 1784
      That's not the HVPS. I see the LVPS, but not HV. Thanks for looking, though.
      • 20 year tech
        • May 2014
        • 577
        they call it the engine power supply procedure starts page 212 in the manual and it is a lot like the 4345 Wild Bill
        • Wild Bill
          • Jul 2005
          • 774
          I was close do I get credit?
          Izzy
          • theengel
            • Nov 2011
            • 1784
            Ok--there it is.
            Unfortunately, the cust. decided to buy a new printer instead of replacing this board. $3000 machine, and it's hardly used. It hasn't even seen it's first fuser replacement.
            • Wild Bill
              • Jul 2005
              • 774
              Dang... offer to buy it and make a little cash
              Izzy
              • theengel
                • Nov 2011
                • 1784
                Cust just called and changed their mind. Will be replacing this board as soon as it arrives. Will post how it goes.
                BTW - This all started because the machine had no power when the switch was turned on. No fans or lights or anything. I found a fuse that was blown in the board that has the AC plug on it... I think that's the DC controller, but I'm not sure. Anyway, I replaced that fuse and plugged it in, and a loud bright spark happened on the HVPS (I could see it). I haven't taken it out yet, but I will next week. Maybe something is laying there making a short.
                Anyway, if you ever have a M4555 with no power, there are two fuses behind the formatter holder that can cause that.
                Just thought I would document this for anyone who might come across the same problem.
                • theengel
                  • Nov 2011
                  • 1784
                  Update:
                  Replaced HVPS (at least a 2 hr job for me) and everything works... kinda.
                  Now there's an intermittent blur toward the trailing edge of prints.
                  I'm gonna start a new thread about that, because I can't figure out what's doing it.
