Update. OK checked the HP part number/Identifier. It is the right add-on 500 sheet unit
Here is the crazy issue!
went out on a PM service call. Had all rollers sep pads etc.
Tray 3 calls for same rollers used in 4200 4250 4350 series (0036's and 0037's)
Here is the baffling kicker. The rollers in machine are smaller diameter more close to a 4000 series.
When I put the "correct" rollers in, the machine makes all kinds of noise and about 70% of time jams.
For the moment is working ok on the "smaller rollers" but will need to be changed pretty soon.
Don't have a clue on difference in size.. Checked parts manual looked around on line. Called 2 printer support areas (Printer Works and Laser Pros International)
Neither of their people ever heard of this issue.
Customer has two of these machines and both have the smaller rollers in them and both have the correct part number for the add-on 500 sheet drawer option on the back frame.
At a loss as to what the tires actually are
