color lj cm2320fxi
  • kei9tha
    • Feb 2014
    • 88
    color lj cm2320fxi
    i need to replace the tray feed tires on this machine and i cant for the life of me get the old tires off. it looks lie the are a half moon tire and you have to release both sides of the white holder. normally hp makes it easy to change feed tires but not this machine. do you have any tricks to getting them off or do i have to find some way to slide the whole shat off the machine? thanks
  • Blizzoo
    • Aug 2013
    • 610
    Re: color lj cm2320fxi
    You must enter in 2ndry Service Menu to do that.
    Press the Left Arrow button and the Cancel button
    simultaneously and select Pick Roller,press OK and the Roller rotates in replacement mode.This sequence is from CP-2020 Manual,i hope is the same.
    • laitang
      • Nov 2012
      • 627
      • Iowatech
        Not a service manager
        • 3930
        I never thought of using snap ring pliers on those tabs, that's going to help me a lot. Thanks!
        • theengel
          • Nov 2011
          • 1784
          Wow--I don't think I've used those in 10 years. I wonder if I still even have any. I've been just using my fingers on those.
