hp m4345
  • Users Tech
    • Nov 2013
    • 85
    hp m4345
    hello everyone,
    need help with hp m4345. copying from top glass or adf and prints are very light. i replaced new toner and tried replacing toner from another machine that has good printouts but problem is the same, light copies and prints, even if i adjust it to the darkest. i've cleaned the top glass and did scanner calibration. do you think this is a laser problem? what else do i need to do? please help.
  • theengel
    • Nov 2011
    • 1784
    Re: hp m4345
    What does the config sheet look like?
    • Users Tech
      • Nov 2013
      • 85
      Re: hp m4345
      black copies becomes gray, very light results. sorry don't have sample copy or print.
      • theengel
        • Nov 2011
        • 1784
        Re: hp m4345
        So when you print a config sheet, that's light also. What I mean is, it's not just stuff from the glass? Not just copies, but anything printed?
        • Wild Bill
          • Jul 2005
          • 774
          Re: hp m4345
          "problem is the same, light copies and prints"
          Transfer Roller
          Izzy
          • Users Tech
            • Nov 2013
            • 85
            Re: hp m4345
            yes that is correct. anything that comes out of the machine is very light.
            • Elmtech
              • Nov 2013
              • 155
              Re: hp m4345
              Check if the economode setting is on. It can make prints look very faint. Also try an engine test if it comes out ok its a formatter or setting issue. If it is bad then you can look at hvps, laser unit etc.
              • theengel
                • Nov 2011
                • 1784
                Re: hp m4345
                Yeah, my first guess would be transfer.
                • ucinn
                  • Jun 2009
                  • 383
                  Re: hp m4345
                  Transfer Roller
                  Transfer roller is first bet, possible dirt on laser glass also can cause this. I would try those two first
                  • Users Tech
                    • Nov 2013
                    • 85
                    Re: hp m4345
                    replaced transfer roller, problem solved. many thanks to all.
                    best regards!
