I have the manual the parts are not even listed unless I am blind. Any body know what the part numbers might be or if they can even be found anywhere?
HP 4535 MFP with broken drum ground spring wire and damaged cover need part numbers
Tags: None
Re: HP 4535 MFP with broken drum ground spring wire and damaged cover need part numbe
For those of you who are not familiar with this part it is on the left hand side when you open the toner access cover. If you look on the toner/drum cartridge on the left hand side you will see that the drum has a grounding portion that protrudes out. As is on hp 4250's etc. Got to have a drum ground or you don't end up with a good print. But what I have found out is it almost looks like the HP 4250 even the cover it is behind. Now with that said, I also found some documentation on the HP4250 stating the part is not available due to they do not sell parts that involve splitting the case to replace. Although you don't need to split the case it is is still in that category they do not supply. So I guess the reason it is not available. I suppose it's time to make my own. I did monkey rig it to work as it broke at the point it is barely sticking out. I took the broken piece, made a small loop and placed it over the protruding broken piece and it is even spring loaded. You know the wire that holds the cover on toner cartridges that opens and closes the flap cover for the drum on say a HP 4250, the wire is almost the same size and flex. I have not tried yet but a person might heat it so it can be fashioned into a a coil and make your own. I hate to resort to that. This is a almost new HP4535, what a shame to toss because of a faulty toner cart. The cart got stuck and the customer forced it out. Nothing new there. So unless there is a third party unit for this spring wire contact, I think we have come to an end on this post unless you want to laugh or make comments. It's ok I can take it.Comment
Most of the parts vendors are stripping machines. That's how they get refurb formatters, lasers etc. There are other companies I know of as well. If you can't find it pm or email me at judd@1stchoiceprinters.com and I'll point you in the right direction.Comment
The upshot is that the only parts you can order from HP are the ones with part numbers listed in the parts section of the manual. And frequently you will need to order assemblies rather than the exact broken part.Comment
