hp lj 9050n error code
+ More Options
Posts
  • Jlozano51
    • Nov 2014
    • 2
    [Error Code] hp lj 9050n error code
    error code 65.12.99 output device disconnected. checked and cleaned 8 bin stacker interface cables and still comes back after awhile. Removing stacker operates ok and no codes.
  • Wild Bill
    • Jul 2005
    • 774
    Re: hp lj 9050n error code
    65.12.99 - Output Accessory Disconnected
    Solution:
    Solution or Workaround: Check all hardware connections first.
    Workaround is to turn off PowerSave. Issue has been resolved in firmware version 08.021.7. Flash firmware to the latest versions of firmware for the whole printer system.
    Found this google give a try
    Izzy
