HP CLJ 5550 Error 59:C0
  • lawdar73
    • Nov 2014
    • 7
    I Have a printer HP CLJ 5550 and is giving an error of 59:C0 I removed the left cover where the Disengaging drive assembly is and i noticed that when its going down it should stop with the photo sensor, but it is trying to continuing going down, could it be the sensor? did anyone had this problem please.
    regards and thanks in advance
    Lawrence
  • Wild Bill
    • Jul 2005
    • 774
    Re: HP CLJ 5550 Error 59:C0
    59.C0 C indicates Cyan and 0 indicates drum drive motor First thing to do is to replace the Cyan Toner Cartridge, then motor, then DC Controller
    Izzy
    • lawdar73
      • Nov 2014
      • 7
      on the manual it says C stands for motor disengaging error and 0 stand for No color black
      rgds
      Lawrence
      • Wild Bill
        • Jul 2005
        • 774
        oops sorry read wrong 59 is some dumb ass motor and I've always had it been a toner cartridge are your toners OEM? if not I still would start w that
        Izzy
        • lawdar73
          • Nov 2014
          • 7
          Yea Toner is OEM , what i noticed as said before when starting the disengaging drive assembly has a sensor in the bottom for the arm to stop, but its not stopping and tries to continue going down than it gives the error after
          • Wild Bill
            • Jul 2005
            • 774
            I maybe should drink some coffee before posting
            Those scare me I wouldn't want to do that one in the field These have a lot of parts that could be broken just dig in I guess good luck
            Izzy
            • Innocent
              • Mar 2015
              • 8
              try to clean the machine first before changing any part,use electronic blower if u have it,remove the four big gears on your left and clean all the sensors
