Fusing Issue HP 4015
  • leonardob
    Owner/Tech/Sales/Crazy
    • Apr 2014
    • 50
    Hi ,
    Having a issue rebuilding the fuser units for the HP 4015 , while with the other models exchanging the the fuser sleeve / Pressure rollers and thermistors bushes and etc works well . We are experiencing fusing problem with the 4015, as the toner does not fuse well.
    We have almost 100 of these machines under service contract , We are using high quality parts (mostly OEM). Does any one can point me on the right direction? Does anyone have rebuild instructions for this unit?
    Many tks,
    Leonardo
    Leonardo B. Brentar
    Managing Director
    Clear Image Technology, SLL.
    P.O. Box – 112720
    Blue Tower – Office 206
    Sheik Zayed Road
    Dubai
    United Arab Emirates
    Phone: +971 4 354 4408
    Fax: +971 4 379 7916
  • Max
    • Oct 2011
    • 581
    Re: Fusing Issue HP 4015
    Dont bother with re build. Just replace the whole thing. Make sure you use the original HP toner as compatible may have a different melting point.
    I know its a lot more money but you will have a happy customer and in fairness the new fuser will outlast your rebuild. We used to have different contracts for customers who wanted original HP toner (a wee bit expensive ) compare to compatible one.
    • theengel
      • Nov 2011
      • 1784
      Are you replacing the heating elements?
      • subaro
        • Oct 2010
        • 1274
        have a cup of coffee and watch 11 minutes, get ready to samba. this is a neat video actually, nice rebuild. By the time you done a couple, you should be a pro.
        • leonardob
          • Apr 2014
          • 50
          On other models (P3015) we do not ,,, It works great ..
          On this model (4015) We tried first to just change the rollers , bushes and thermistors .. I did not work ... In one unit we change the heat element and it improved... We also tried to play with the pressure springs of the rollers .. no luck .
          Tks,
          Leonardo
          Leonardo B. Brentar
          Managing Director
          P.O. Box – 112720
          Sheik Zayed Road
          Dubai
          • subaro
            • Oct 2010
            • 1274
            Ok, if you want to see where your problem persist, try the following. Take a fuser that you know is working well, remove the sleve and pressure roller and put it into the fuser that you rebulid and is not fusing properly. if this does not work, then pressure springs ect. continue untill you find he part that is making the difference.
            On the video, i saw the guy remove he old thermal compound and put new paste, did you do this step.
            • leonardob
              • Apr 2014
              • 50
              Thanks !!! Nice !!! Herbie Hancock on the background and a "Cafezinho" on my hand ... Not much different form what we do , but their Heat Element look in better condition than the ones we've seen .
              I'll try again .. and will put the back ground music ... it may help.
              Leonardo B. Brentar
              Managing Director
              P.O. Box – 112720
              Sheik Zayed Road
              Dubai
              • leonardob
                • Apr 2014
                • 50
                Yes, we use the OEM compound (grease) ...We did not have new pressure springs , but tried to add a thin washer under it to increase pressure ... did not work. I'll be ordering new parts , will try with different Fuser Sleeve (the OEM one) and new springs ..
                Leonardo B. Brentar
                Managing Director
                P.O. Box – 112720
                Sheik Zayed Road
                Dubai
                • Abimotek
                  • Feb 2015
                  • 59
                  What's the current state 220v or 110v? If i get the print out problem, it duplicate/double the copy print out
                  • leonardob
                    • Apr 2014
                    • 50
                    220 V ... the problem is fusing ...the toner does not fuse well on the paper ...normally in one side of the page ... EG .. when printing the machine status pages ( with a solid black header ).. I can remove some of the toner by rubbing the finger on it ( mostly on Top Left Corner) .. the pasrt not fusing will apper down somewhere on the page.... When back at the office will scan a sample and post.
                    Leonardo B. Brentar
                    Managing Director
                    P.O. Box – 112720
                    Sheik Zayed Road
                    Dubai
                    • Wild Bill
                      • Jul 2005
                      • 774
                      if you haven't already, make sure your test machine or what ever printer you install these in have the latest firmware. There was a problem with fusers/firmware but thanks for the video.
                      Izzy
                      • daleb1
                        I finally put a OEM fuser in my and fusing issue went away
