Hp 3005 black copies and not reading toner cart
  • lenovos
    • Oct 2012
    • 141
    I had a printer giving intermittent black copies and misreading toner cart, which i thought was because of katun toner.
    The problem was actually a faulty drum ground. The fix that seems to work is removing left side panel and taping a piece of cardboard to the levers that apply pressure to the drum ground. The katun toner turned out to be fine.
  • d7guitar
    • Jan 2007
    • 54
    Re: Hp 3005 black copies and not reading toner cart
    You are correct. I've seen this many times. I carry window strip insulaion for this fix. since it already has sticky tape on one side it works great.
    After all is said and done, More is said than done.
