Need part number of end fence tray 4 HP 9040
  • dan7777
    • Dec 2012
    • 680
    [Misc] Need part number of end fence tray 4 HP 9040
    Can anyone tell me the part number for the end fence in tray four in a HP 9040. The manual I downloaded does not show it. The part on the floor has the tabs broken that hold it in the bottom of the tray. Thanks.
  • subaro
    • Oct 2010
    • 1273
    Re: Need part number of end fence tray 4 HP 9040
    That part is not avaliable separate as to the parts manual. you have to purchase the entire tray.
    time for expoxy and your inventive mind or look for a use one in your area.
    • dan7777
      • Dec 2012
      • 680
      Thanks. I thought about epoxy. It is a billible call and I was not sure if I should do that. Do you have any idea about the grey (extension/lever) on the side? It looks like it goes behind a white lever for size. I am not sure if it just sits behind it or attaches to it?
      Thanks for replying.
      • subaro
        • Oct 2010
        • 1273
        I'll check that for you when i go the the shop in the morning. don't work too often on these anymore. I have disassemble this unit once as the paper size was not proper and it took a bit of time to figure out the proper way of reassembly . take photos if you are going to disassemble.
        • dan7777
          • Dec 2012
          • 680
          Thanks. I could not get back here for a while. I sent them an estimate for the entire tray. Supposed to hear back when someone gets back from vacation. If that piece has to be in the correct position I could run into trouble if I glued it down. We don't sell the HP's. No one around this small town works on them so I get a lot of calls. I have no clue on most calls but Google helps a lot of the times. I appreciate your help. I assume the printer justs lifts off the tray and sets down on a new one.
