Error 10 - Supplies Memory Error 10.XX.YY Exact format is dependent on printer model
  • FCNSC
    • Jul 2025
    [Error Code] Error 10 - Supplies Memory Error 10.XX.YY Exact format is dependent on printer model
    1. Supplies used in newer printer models contain a memory chip. The information contained on this chip is dependent on the printer model and the supply. The error 10 indicates a problem with the printer obtaining the information from this chip. The chip may be missing or defective or contain incorrect information. There may be a problem with connection between the memory chip and DC controller. Turn the printer off/on to attempt to clear or reset the message. Remove and reinstall the supply, replace the supply.
    2. Replace the memory chip cable/connector or the DC controller.
    How did we do
    شركة مكافحة النمل الأبيض بالرياض
  • Wild Bill
    • Jul 2005
    • 774
    Re: Error 10 - Supplies Memory Error 10.XX.YY Exact format is dependent on printer mo
    I think I speak for all of us when I say...
    HUH?
    Izzy
