M575, I need another opinion.
  • fixthecopier
    ALIEN OVERLORD
    • 4714
    The machine was unboxed over a year ago, I was called because the control panel was black. I resolved the issue, they put it back in the box, as a spare, stored it on it's side then go to use it and it codes for the scanner, 39.01 something. I can't remember the last 2 on the code. Anyway, it was a scanner issue. I researched the manual, then went online and looked at HP forums.
    So I reset the machine to factory specs
    Changed the scan bed
    Changed the scanner control board
    It was still coding, took it back to customer and swapped formatter with one that was working, still codes.
    At this point they now have a parts machine for the other 20 of these they have unless one of you more knowledgeable folks can enlighten me as to what is going on.
  • Wild Bill
    • Jul 2005
    • 774
    Re: M575, I need another opinion.
    DC controller is my guess but I haven't seen those to much.
    Good luck Fix!
    Izzy
