Error 52
  • mdfurqan2012
    • 194
    Error 52
    Dear All,
    I have HP M1522nf giving error code 52 on startup.
    I think this is error code fir incorrect scanner speed.
    Kindly Guide me how can i fix it.
  • prntrfxr
    • 1622
    Re: Error 52
    It will probably be either the Laser Scanner or the ECU. On a small machine like that it will probably cost more than replacing the machine if you buy OEM parts. Even on refurbished, by the time you add your markup and labor, the customer will be better off buying a new one and have a warranty.
