CM4730 duplex turn around delay jam
  • Iowatech
    Not a service manager
    • 3933
    [Jamming] CM4730 duplex turn around delay jam
    If something like this is causing you fits, there is a sensor feeler just past the fuser that has a rubber pad on it that wears out and causes the feeler to get hung up. Clean the pad off of the feeler and you should be good to go.
    I've got a picture of where that is at, but for some reason I can't upload it right now. My fault, sorry about that.
    Still, if you remove the finisher and the bridge unit (sorry, Ricoh terminology) the sensor feeler should be easy to spot, and if you manually move the feeler around and it sticks in the upper position you have found the culprit.
    Hope that helps.
  • Iowatech
    • 3933
    Re: CM4730 duplex turn around delay jam
    Well, I had to convert the picture to a pdf to upload it, sorry about that. Still, here it is.
    The red plastic tweaker points to where the offending pad is at.
    CM4730 jam pad.pdf
