CM6040
  • ATSBMCO
    Technical
    • Oct 2007
    • 70
    CM6040
    I'm having a bit of an issue with this model. The paper is getting stuck in the transfer belt; literally into the belt cleaning blade area. Its as if the secondary transfer roller isn't powering up to help remove the paper from the static charge of the belt.
    I've checked the connections are right, and cleaned and checked the condition of the secondary transfer unit.
    The machine has had a brand new main transfer belt and also a new Fuser installed too.
    Any ideas would be appreciated.
  • Hewlett Slacker
    • Apr 2015
    • 42
    Re: CM6040
    whats the event log say?
    • theengel
      • Nov 2011
      • 1784
      Re: CM6040
      Does the secondary transfer have some sort of separation charging grid? I would probably start by replacing the entire 2nd transfer assembly... not just the roller.
