How to install an HP4200/815mfp scanner on Windows 7
  • pgodfrey
    • Jul 2015
    • 14
    I documented (as best as I can), how to install a Hewlett Packard Designjet 4200 / Designjet 815mfp scanner on Windows 7 (64-bit).
    You can download WIDEsystem here; CHROMA G600 / Spectra 600e | Contex Large Format Scanners and Software
    You'll want to download 'WIDEsystem Installer' -- Version 3.9.1 Build 38072
    (text version below) -- PDF attached with images.
    Install WIDEsystem Driver Download -- restart if necessary -- ignore software if it loads
    Right click on 'computer'
    Select 'Properties'
    Select 'Device Manager'
    Right click on 'Contex hp815mfp IEEE 1394 SBP2 Device'
    Select 'Properties'
    Click on 'Update Driver'
    Click on 'Browse my computer for driver software'
    Click on 'Let me pick from a list of device drivers on my computer'
    Click on 'Imaging devices' then click 'next'
    Scroll down in the 'Manufacturer' to 'Contex A/S'
    Scroll down in the 'Model' to 'HP Scanner (1394)'
    Click 'Next'
    You will be prompted "Installing this device driver is not recommended...", click 'Yes'
    If you have Windows Security popup, click 'Install this driver software anyway'
    The next window to popup is "Windows has successfully updated your driver software", click 'Close'
    If you open WIDEsystem, you should see your scanner is installed.
