Print outside same network
  • Printer77
    • Sep 2019
    • 55
    Is it possible to print with Lexmark MX417DE outside of same network?
    • 29359
    Re: Print outside same network
    Depends on many factors
      It's absolutely possible. There are different ways of doing it depending on your network environment. One way is via inter-vlan routing. A Windows 10 PC can also have 2 IP addresses.
      • Printer77
        • Sep 2019
        • 55
        Can it use "Google cloud print" services? If yes how to set it up?
          We're talking about 2 different things. If you use a 2nd IP address on your PC, it will allow you to connect to a second network and the printer that's on that network. 'Google Cloud Print' allows a user to print over the web.
          Check out this video:
