Lexmark X502n
  • spree
    • Jun 2012
    • 211
    Lexmark X502n
    I have Lexmark X502n colour MFP and it copied with very low contrast. Printing was OK.
    I cleaned the scanner assy with glass and mirror cleaner and after then the wide black stripe (around 8cm) appeared.
    Then I made another cleaning of mirrors and glass, but another black stripe appeared also on left side.
    So now, I have on the right and left side wide black vertical stripes.
    It appears through ADF copying and also glass copying.
    Where can be the problem?
    Thanks.
  • draph
    • 132
    Re: Lexmark X502n
    You know the old saying, "if it was okay before you worked on it, re-trace your steps." First guess is that you got something back together incorrectly when you took apart that scanner.
    • spree
      • Jun 2012
      • 211
      Re: Lexmark X502n
      I've tried to make same steps again.
      No black stripes, but the text is blurry and missing sharpness.
      The scanner didn't scan it like really looks it, but I hope for example it's enough.
      Before:
      After:
      Have you some idea, where can be the problem, or what to do to have same sharp text as before?
      • draph
        • 132
        Re: Lexmark X502n
        That looks more like a bad toner cartridge. Stop it mid cycle and see if the image on the drum is dark.
        • spree
          • Jun 2012
          • 211
          Re: Lexmark X502n
          The prints from the device menu are OK.
          It happenes only when copying, so probably there must be something with scanner assy?
          I tried to clean only mirrors. I cleaned it several times same way on HP machines with no problems afterwards.
          • Iowatech
            Not a service manager
            • 3930
            Re: Lexmark X502n
            Chances are you will need a new scanner unit. I have tried to clean Lexmark scanners, but have found it to be a waste of time as it never solves the problem for me.
            I guess you might double check the white reference strip to make sure it isn't dirty, but more likely than not the CCD is failing. And a new scanner unit is the only solution for that.
            Luckily, if you have the service manual, the scanner isn't that hard to change, and it wasn't as expensive as I thought it would be.
            • spree
              • Jun 2012
              • 211
              Re: Lexmark X502n
              What can caused the different image after every three disassembly, cleaning and assembly? The white stripe?
              • Iowatech
                • 3930
                Re: Lexmark X502n
                As far as the streaks go, it could have been the CCD circuitry trying to reset after you turned the machine on, and having trouble reading the outputs from a different group of elements in the CCD. Or it could be as simple as some dust in the scanner that you moved when you were cleaning it. It really doesn't take that much contamination inside the scanner to cause streaks.
                The print quality displayed in the pictures could be caused by the white strip. As that is what the scanner uses as a reference for white, if the white strip is dirty the machine will make light copies.
                • spree
                  • Jun 2012
                  • 211
                  Re: Lexmark X502n
                  CCD Reset - you mean Factory default settings, through "Clear menu settings" ?
                  If yes, think I've tried it, but can do it once more.
                  • Iowatech
                    • 3930
                    Re: Lexmark X502n
                    Actually, when first turned on, one of the things the machine does is scan the white strip, and then checks the output value of every element in the CCD against the expected output. If the machine detects differences in any of the elements of the CCD, it tries changing things so that the output value is the expected value. If the white strip is contaminated, it can cause problems during that procedure.
                    You probably already know that. Sorry, I should have explained that better.
                    • spree
                      • Jun 2012
                      • 211
                      Re: Lexmark X502n
                      I've locked the scanner and moved the MFP only some kilometers.
                      After arriving on place, I've turn MFP on unlock the scanner and make a black copy.
                      Unfortunately, not only the black stripe appeared again
                      It's the same from the ADF and glass.
                      lease, have you some ideas, what can I do to repair the black stripe and ideally to make copies sharper?
                      Would be very appreciated.
                      Then I've tried reset settings, then turn off and turn on MFP and voalla, the black stripe is away.
                      I've made another black copy, it's still blurry, but when I've made a color copy, the contrast is great...
                      Have anyone some ideas, please?
                      Black copy
                      Color copy
                      • Iowatech
                        • 3930
                        Re: Lexmark X502n
                        The scanner unit is malfunctioning, and needs to be replaced.
