Having print quality issues , not getting good fill on the nozzle check and getting black streaks with kind of a swishy look , not consistent , like crud on the underside of the printhead . Tried cleaning the printhead thru the op panel like an end user , then tried putting a paper towel under the printhead with head cleaner on it and let it soak for a couple hours , then wiped with a dry Paper towel . Still no better . Does anyone have a service manual or any ideas how to proceed ? The printhead is buried and is fed from bags of ink on the side of the unit thru tubes , so I can not purge this unit as sometimes works . Thanks in advance , Ark .
Epson WF-R4640
Re: Epson WF-R4640
one trick I have found... take a paper towel fold n cut to fit in the track where the printhead runs. Wet the towel with Simple Green Cleaner... push printhead over towel... now spray and blot up the docking station ( be sure to clean the wiper blade well ) ... let it sit for about 30 or so minutes ..remove towel and try a nozzle check. This has worked on every Epson... HP...Brother..and FP ink/heads.... so far about 30 machines... -
Re: Epson WF-R4640
i have the service manual... give me your email addy.
I have the same issue with my Epson Workforce Pro wf-r4640 printer that the above post was replying to. I would very much appreciate it if you could share the link to the service manual with me so I can hopefully take care of this problem.
My email is keaoku@hawaii.rr.com
Thanks,
EricComment
Re: Epson WF-R4640
TYSM!Comment
