Fujitsu N7100 Scanner Factory Reset (without Password)
  • TonyKennard
    • Dec 2024
    [Misc] Fujitsu N7100 Scanner Factory Reset (without Password)
    Hi,
    Can anyone advise how I reset a Fujisu N7100 Scanner back to factory default without using the Admin Password?
    Tony
  • michel2582
    • May 2022
    • 1
    Re: Fujitsu N7100 Scanner Factory Reset (without Password)
    Originally posted by TonyKennard
    Hi,
    Tony
    I have the same question, did you figure out how to do this Tony?
    • neuling
      • May 2023
      • 1
      Hi!
      Any news about how reset the Fujitsu N7100 Network Scanner ?
      Thanks a lot
      Answer to me self ...
      Fujitsu N1800 / N7100 etc ...
      user: Admin
      password: ALT+1, CTRL+2, ALT+3, CTRL+4, ALT+3, CTRL+2, ALT+1
      Source: https://youtu.be/iyYECHPUPcM
      • ashish82
        • Jan 2024
        • 1
        I followed the exact procedure on my Fujitsu N7100 but with no luck. Goes on to say unable to connect LDAP server. Is there a trick to entering the password? Any tips or tricks
        Originally posted by neuling
        Hi!
        Thanks a lot
        user: Admin
        • kevinw
          • Jan 2024
          • 1
          Hello,
          I have 2 of units they have the same issue if you use the factory default admin log and password as suggested buy the Fujitsu help desk. You are able to restore to factory in the admin panel but I get: "an error was detected scanner alert monitor" warning on startup. You can bypass it but Fujitsu says it needs service. However the unit would boot fine prior to the admin reset. Anyone else have this issue? Find a solution?
          Initial Factory response, same as above post does not work on my scanners. I think the video unit is logging in as a user:
          To reset the N7100 series scanners back to factory defaults do the following:
          Warning! DO NOT use this procedure to do a password reset! For password reset issues see {[KBID 520235]}
          The following steps will cause data and/or system configuration loss and cannot be undone. This should only be used as a last resort!
          Note: Using an external KB can make this process easier on certain scanner models
          1. At the network scanner touch screen log on prompt, enter Admin as the user name.
          2. For the password, enter Alt+1, CTRL+2, ALT+3, CTRL+4, ALT+3, CTRL+2, ALT+1
          3. Press [Login].
          4. It will now ask you if it is ok to overwrite your data, click [OK] and the scanner will reboot to a factory default state.
          • GlennC
            • Aug 2024
            • 1
            I'm having the exact same problem, Kevin. Tried using this solution, and it just says it isn't the correct password. Did you ever get this figured out?
