Failing Touch Screens on several copier brands.
  • Hansoon
    • Sep 2007
    • 3385
    Re: Failing Touch Screens on several copier brands.
    No, mobile phones and I-Pads are very different. My method will not work on these.
    Hans
    • 907tec
      • 434
      I don't know what these other guys are smoking...I'm happy to see somebody repairing these things. Touch screens for a dollar? Not from any of my suppliers. Thankfully, I haven't been plagued by unresponsive screens, but I will definitely contact Hans if I get one. Hans is a class act and one hell of a technician. His research into the KM Bizhub developer collars was extraordinary and resulted in the manufacture of a brilliant modification: so brilliant that Konica Minolta copied his idea shortly thereafter. Don't dis Hansoon.
      • loverkoko
        • 35
        i wnat to know how to fix touch screen at model ricoh 3045
        • ddude
          General Troublemaker
          • 473
          #19
          This I very much agree with; Hans has fabricated a Konica mod that saves the dealer much money and stress, I would have confidence in any repair he can create.
          2000 mockingbirds = 2 kilomockingbirds
          • Lagonda
            • Aug 2008
            • 1649
            #20
            Originally posted by Hansoon
            Takes indeed about 30 minutes all inclusive such as preparations and testing. It needs also special chemicals and application devices.
            Hans
            If it was that easy why didn't Ricoh want the mountain of duff screens back to repair? The could have saved themselves a fortune recycling old ones rather than manufacuring new ones.
            If only they had used a silicone adhesive that didnt absorb moisture they wouldn't have had a problem to start with.
            • Hansoon
              • Sep 2007
              • 3385
              #21
              It IS that "easy" if you have the proper materials and procedure.
              Hans
              • jonezy999
                just one copy??
                • Feb 2010
                • 952
                #22
                Several copiers are suffering from failing touch screens. They become unsresponsive.
                I have developed a method to repair those screens with guaranteed lasting results and planning to set up a repair service here in Europe as well as the US perhaps.
                I know that many large brands are having these problems.
                Kindly give me some information which brands and machine types are affected.
                Thanks in advance.
                Hans
                The original question.
                Ricoh's first series of colour touch screens all had the same issue with absorbing moisture. These are really the only unresponsive screens I have came across. Like I said in my first post here, Ricoh were all over this, supplying free of charge screens.
                Other than that, I have seen one Toshiba e-2820c, which was repairable and a Canon ir3235, which is unrelated to the screen completely.
                I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
                • jonezy999
                  just one copy??
                  • Feb 2010
                  • 952
                  #23
                  L
                  ooks like Lagonda may have a few ready for you to put back out into the field here.
                  http://www.copytechnet.com/forums/ra...chscreens.html
                  • Hansoon
                    • Sep 2007
                    • 3385
                    #24
                    On request:
                    Hans
                    • copiman
                      • Sep 2011
                      • 861
                      #25
                      Each copier manufacture contracts to a third party company to manufacture the displays and other parts of the copiers. The ones that Ricoh had a problem with were also used in the Panasonics. Its the exact same display. Although it is true that Ricoh and Panasonic do replace them for free, for how long will this last? Don't know. Hansoon, good luck in your quest. I wish all the success with it.
                      • Mooseface2r
                        • Jan 2011
                        • 114
                        #26
                        We get the problem on the Old Konica C250
