Ricoh MPC5502 & 5501a SPDF
  • Hadster
    • Aug 2011
    • 264
    I have manuals for both machines but cannot find anywhere a manual for the single pass doc. feeder = SPDF ( D642 - MPC5502 ). I'm not sure of the model for the MPC5501a. I normally get manuals through Service-manual.net but can't find them there either. Help, please!!!
  • FrohnB
    • Jul 2017
    • 1919
    Re: Ricoh MPC5502 & 5501a SPDF
    Are you looking for a Service Manual or a Parts Manual?? The D143/D144 (C4502/C5502) Service Manual has the replacement and adjustment section for the DF3010/DF3070. And it Also has the SPDF (C4502A/C5502A Only) in it under the first Replacement and Adjustment section.
    EDIT: There is a Parts Catalog for each model Doc. Feeder. (3010/3070/ D642)
    Omertà
    • tufbnme
      • 493
      Weird that there is no service manual for the SPDF. I looked through Ricoh and found nothing. I have the parts manuals if you need them.
        • 37168
        Since the SPDF is default equipment for the MP C5502, the service information is part of the main service manual. You have most likely made the mistake of searching the manual for SPDF. In the Replacements and Adjustments section between ELECTRICAL COMPONENTS and USING DIP SWITCHES you will find the section SINGLE PASS ADF (SINGLE PASS ADF MODEL ONLY). It should have all the information that you need.
        • tufbnme
          • 493
          But nothing on the 01 series SPDF
            • 37168
            SP modes for the SPDF are in the SP table. Again search for single pass.
            • Hadster
              • Aug 2011
              • 264
              Are you sure about that? I know it is default on the 03. I thought the reason for having an MPC5502a vs MPC5502 was the SPDF came only on the "a" model. Which is why I'm having such a great time finding the parts manual so I can order the parts you recommended. Shafts and one way bearing for adf belt slippage.
                • 37168
                I take it that you are too lazy to open the service manual and check. I did before I made my reply that you quoted and I just rechecked it. If you had read FrohnB's post you would know there is a parts manual for it. Or are you not with a Ricoh authorized dealer and therefore do not have access the rfgesource?
                • Hadster
                  • Aug 2011
                  • 264
                  I do not appreciate being called lazy! You are right, I'm not an authorized Ricoh dealer. I am however a small business owner who puts in 12 hours days busting my ass to make a living! Forgive me for not being able to find what you're talking about with the other 20 things I have on my plate at this moment. All I need is parts manual to order the parts I need anyways.
