Epson R2880
  • cosmin_mocanu
    • Dec 2008
    • 71
    Epson R2880
    Ineed a service manual for thei machine. It does nor recognize the cartridges. If i putall the cartridges it says that all the cartridges are non genuine. If i remove one, ore more cartridges, it recognize the ones mounted in the printer but then i put then all error. Could anyone help mee? I tried with genuine and non genuine cartridges, all brand new and the same err.
    Thanks in advance for your suport.
  • vlad_robas
    • Oct 2006
    • 225
    Did u put in the same time oem and compatibile? This usualy happend's on Epson if u have an older version of chip's on the cartridge's or u have compatible cartridge's instaled. I didn't worked on this model but i have some P50's which i did install CISS system's and when CISS board failed i did put chip's, Ver. 6. I would try harder with OEM cartrige's and maybe an firmware update and check if there isn't any broken contact betwen chip and board.
    • cosmin_mocanu
      • Dec 2008
      • 71
      I do not find the firmware update for this model. And it is safe to do an firmware update for this model if it is not ready to print? I only tried whit ciss , OEM and refillable cartridges separate ( all 8 cartridges from the same producer ). I realy think it is an firmware isue.
      • cosmin_mocanu
        • Dec 2008
        • 71
        Comming back with some details. If i mount 7, or less cartridges, the printer reads the info on the cips with noo problem ( date of fabricaion, manufacturer etc). If i mount all the cartridges ink out error.
