Canon ir3530 print kit install instructions
  • kuby
    • Oct 2007
    • 1395
    Does someone have the install instructions for the print kit for a ir2230/3530 series. I am installing one and now the copier just continues to reboot after a little while, again, again, and again. Maybe I am missing something? Thanks
    PDL-E2 print kit
  • JustManuals
    • Jan 2006
    • 9838
    Re: Canon ir3530 print kit install instructions
    Do you have the model number of the print kit?
    • kuby
      • Oct 2007
      • 1395
      PDL-E2 print kit
      • JustManuals
        • Jan 2006
        • 9838
        I've only got the Parts & Service manual.
        Paul
        • mjarbar
          The installation instructions are a part of the service manual.
          Please be advised that you also need the additional expansion RAM 256Mb-B1 card for the installation (sold separately - which doesn't help!!!) which may be giving you the constant reboot problem.
          • Simons
            • Jun 2008
            • 490
            When this happens you should call Circuit Board Repair, Canon, Ricoh, Savin, Lanier Gestetner, Konica, Kyocera Mita - Nation-Wide Repair Service, Inc. (NWRS) and never forget about memory requirments when installing print kits! Including HDD.
            • kuby
              • Oct 2007
              • 1395
              Bad memory, Brand New but bad.
