Toshiba Estudio feed rollers
  • jonbonse
    • Jun 2009
    • 737
    Hi all
    Im looking for the cassette 2 pickup, feed and Sep roller part numbers for the 2050c.
    Can anyone help?
  • Blizzoo
    • Aug 2013
    • 610
    Re: Toshiba Estudio feed rollers
    6LK50755000 - Rol Kit Urethane type
      • 8255
      With the orange tint urethane type, there is no clip on the roller to hold it in place on the metal shaft. Are you suppose to pit a U clip after the roller?
      The regular rubber replacement rollers have a clip built in.
        • 8255
        With the orange tint urethane type, there is no clip on the roller to hold it in place on the metal shaft. Are you suppose to put a U clip after the roller?
        I can answer my own question. If you are replacing the regular black rollers with urethane rollers, you are going to have to find some U-shaped clips to hold them in place otherwise the urethane rollers will easily slide off the metal shaft when in use.
        I think the appeal of the urethane rollers is that they last longer than the original black rollers that were installed on a e507 series.
        • jonbonse
          • Jun 2009
          • 737
          Thanks all
          Does anyone have the original roller part number(s)?
