Hi, hope someone can help. I am in the UK and have a customer that only uses American size paper. THe copier has been setup to use both AB/ INCH settings. When they scan ltr-r off the glass it shows up as LGL. This is because the european machines only have 1 vertical position sensor (PS104) due to metric sizes. In the service manual it shows an additional sensor for AB/inch settings. Does any one have a part number for the second sensor (PS105), the cable and holder for the sensor?
THe UK parts catologue only shows ps104 using a 3 wire cable to j110 on the reader board. The circuit diagram shows that j110 is a six pin connector with 3 unused pins with the correct outputs for a second sensor. Is there a six wire cable to two 3 pin connectors for the second sensor available? Is there a seperate holder for the second sensor, or is it 1 piece of plastic that holds both sensors? if so what is the part number? thanks in advance.
