Kyrocera M2535dn PWB panel assembly # 302PK94050 install?
  • mark.saracino1@juno.com
    • Nov 2023
    • 3
    The number "2 ABC" button on the key panel does not work on my Kyrocera M2535dn.
    I can obtain a replacement for $86.00 from HytecRepair.com and would like to know how to install it.
    Does anyone know of a video I could view or could someone guide me through the process by voice or videoconference for your fee?
    Using the key panel to enter fax numbers without the digit "2" works fine as does entering the fax number on the desktop, but the full key panel usage is beneficial.
    I look forward top hearing from you. PWB panel assembly # 302PK94050
    Thank you
  • ronny2502
    • Mar 2020
    • 79
    Re: Kyrocera M2535dn PWB panel assembly # 302PK94050 install?
    Hello,
    I use this printer at home.
    I'll try to test it on the weekend.
    Best regards,
    Ro
      • Nov 2023
      • 3
      Thank you, Ro.
      I wait.
      Have a nice weekend
      Originally posted by ronny2502
      Hello,
      Best regards,
      Ro
      • ronny2502
        • Mar 2020
        • 79
        Hello,
        I just finished removing the “PARTS PWB PANEL ASSY SP” (302PK94050 // 302MH94090).
        It is not complicated. Even if you are new to Kyocera it takes not more than 30 minutes to replace this board.
        Find a manual with pictures here:
        Download - UploadNow.io
        Good luck!
        Ro
        PS: In case the link does not work, contact me again.
          • Nov 2023
          • 3
          Hi Ro,
          The panel of imge you provided is beneficial, but the removal and replacemnt fo the part requires soldering. I do not have a solder gun, althought I used to be able to solder.
          I may just continue to fax via the print function using the dialogue box to ask the printer to fax, then entering the fax number at the desktop.
          Thank you much for your efforts.Appreciatively.
          Mark
          Good luck!
          Ro
