Kyocera 3252ci - belt cleaning motor gears
  • kuby
    • Oct 2007
    • 1409
    Is there a parts break down for the DR-8350 (302L793120) drive assy. for the 3252ci. The belt cleaning motor and the 40/21 gear that it drives has some worn teeth. Took motor and gear out of another machine and the customers machine is up and running again. Just would like to order them so I would put the other machine back together. Do you have to order the whole assy.? Seems a waste for just a few little parts.
  • kuby
    • Oct 2007
    • 1409
    Re: Kyocera 3252ci - belt cleaning motor gears
    Found the gear and a motor.
    wormwheel drive gear - 302K021480
    parts DC motor assy - 302ND94050 (has a different color gear but thinking it will work)
