Konica/Minolta Di3510 copier/scanner - rear cooling fan
  • T588
    • Aug 2025
    RE: Konica/Minolta Di3510 copier/scanner
    Fan label:
    Minebea
    p/n: 3110KL-05W-B69-JA5 - (the last 3 digits are in a small box below the preceeding numbers)
    The rear cooling fan is failing (bearing failure)
    I contacted Minebea directly and they have no listing of a JA5 - they said the possibilities are D00, D50, G00 or G50.
    I went to the Digi-Keys wedsite and located the fans Minebea lists but the problem is I don't know if the existig JA5 features a "Locked Rotor" sensor or a "Speed (Tach)" sensor.
    Can someone elighten me as to which fan is a direct replacement for the 3110KL-05W-B69-JA5?
    Any assistance would be appreciated.
    Thanks...
    Vinnie
  • 907tec
    • 434
    Re: Konica/Minolta Di3510 copier/scanner - rear cooling fan
    Which fan are you looking for, exactly? Any reason why you aren't ordering it as a KM part, rather than from KM's supplier? You will probably have much better luck finding it as a copier part, rather than a miscellaneous electrical component. Precision Roller has em, not the cheapest though.
    Fan Motor M6: 9313-1100-51
    Fan Motor M5: 9313-1100-33
    Fan Motor M10: 9313-1100-51
    Fan Motor M4: 9313-1100-42
