Integrated Circuit MM74C914 datasheet
  • jojolucky
    • May 2025
    MM74C914
    Hex Schmitt Trigger with Extended Input Voltage
    Features
    n Hysteresis: 0.45 VCC (typ.) 0.2 VCCguaranteed
    n Special input protection: Extended Input Voltage Range
    n Wide supply voltage range: 3V to 15V
    n High noise immunity: 0.7 VCC (typ.)
    n Low power TTL compatibility: Fan out of 2 driving 74L
    General Description
    The MM74C914 is a monolithic CMOS Hex Schmitt trigger with special input protection scheme. This scheme allows the input voltage levels to exceed VCC or ground by at least 10V (VCC -25V to GND + 25V), and is valuable for applications involving voltage level shifting or mismatched power supplies.
    The positive and negative-going threshold voltages, VT+and VT-, show low variation with respect to temperature
    MM74C914 datasheet and PDF downfrom ChinaICMart
