C654 FS-534 C-1105
  • JR2ALTA
    • Feb 2010
    • 2028
    C654 FS-534 C-1105
    Code is constant at warm up. finisher goes through it's warmup motions with no signs of binding or nosie then bam!
    Any good fix for this? read the bulletin regarding clips. this machine has clips. Also ordered the free of charge "encoder discs.
    thanks in advance!
  • splblazer91
    • Jul 2014
    • 204
    Re: C654 FS-534 C-1105
    Usually when I have had this happen one of the actual encoder wheels had fallen off its shaft.
    • JR2ALTA
      • Feb 2010
      • 2028
      thanks. I will look for that. I never heard of the term before today. Encoding is typically a term used in digital media, haha. i think it's something like a pie wheel used for timing?
      • splblazer91
        • Jul 2014
        • 204
        yup thats it. It looks like a slotted disc. should be 2 of them.
        • JR2ALTA
          • Feb 2010
          • 2028
          It was the "encoder disc" broken, easy to replace. Just remove the exit side tray and panel, boom there it is
          • smfeld
            • Dec 2019
            • 1
            Here is the part number, that konica says can be ordered free of charge is: A3EPPP7402
            • Synaux
              • Mar 2012
              • 1224
              I am not one to judge, but what is going on here: This is your one and only post. You joined almost a year ago and as your first post you respond to a 5 year old post.
              • wjurls
                • Feb 2017
                • 492
                One post yet 2 red cards!
