Hi There,
Getting frustrated with machine getting in to lock-ups and can't get it to run again until I disconnect the HDD, then do couple of reboots, trouble reset, then it works on occasion.
Then it comes back after xyz days or weeks and it locks in such a way that even HDD disconnection doesn't help.
Re-flashed firmware on each visit as a routine
When it started occurring we replaced power lead and network cable, changed sockets and network port. Machine had scanning issue (corrupted files) couldn't be opened or defective image. That time replacement of network lead and change of port solved the issue. Few weeks down the line again machine locked (usually after weekend) so thought maybe PWR supply is getting wacky. Replaced and no difference it made as it locked again. Replaced memory modules (from a working machine) and machine happily worked for a month and a half when it locked again.
Replaced MFPB...flashed FW...NV RAM Clear...Setup...FW..worked..for a while.
Replaced with NEW HDD machine worked for a while again locked
Last time it locked that disconnecting of HDD did not help or trouble resets until I did NVRAM clear and then it would work but only with different HDD Cable??, was very pleased with that is it was a lot faster and everything worked well.
This morning...after a weekend...locked again. I am running out of options...
