KM Di470 turn on controller?Set Ip?Help!!!
  • michael517mi
    • Jun 2025
    Installed pi4700e onto a Di470 and don't know how to tell machine its there and set the ip for the network. My customer is getting anxious. Help me please!
  • stacyrf
    • May 2008
    • 40
    hello Michael,
    set the controller type to 0 in the tech rep mode.
    ip settings are in the admin settings. after you enter the admin number there should be a button for network settings on the bottom of the screen.
    • michael517mi
      Ok it is a Pi4700 on a Di470 and controller type is set to 0 and there is no Network settings button showing in admin settings. Any ideas? I'm not familiar whith this controller or set up.
      • michael517mi
        fixed
        Hytec helped with set up info and then had bad nic, fixed now. Thanks all.
        • jimmyisec
          • 12
          Re: KM Di470 turn on controller?Set Ip?Help!!!
          How you fix it let me know please
          • Hansoon
            • Sep 2007
            • 3374
            All of this type of NIC's go bad. The same NIC is used in the Di-351 series and is having the same problem.
            Our company has rebuild NIC's with modified components and the latest firmware.
            touchpanel[at]rex-technika.com
            Hans
            โ€œSent from my Intel 80286 using MS-DOS 2.0โ€
