Bizhub 163
  • zaza
    MECANOGRAPHE
    • Mar 2008
    • 1095
    [Misc] Bizhub 163
    hello all technician friends ...we have Bizhub 163 ...if we chose in the box paper A3 it is not ...always he affiched B5..l clean all detector but never pls how l can do it ?
    BEST TECHNICIAN . NICE PEOPLE .
    • 22954
    Re: Bizhub 163
    May I assume that you are having some sort of a problem with paper size detection? The next question is: Is it detecting the original incorrectly, or is it detecting the copy paper in the paper tray incorrectly? =^..^=
    • Hansoon
      • Sep 2007
      • 3355
      Re: Bizhub 163
      If not a sheet of paper is tucked behind the tray pushing the sensor arms then I presume the little frame which carries the sensors got bend. This happens when the machine is being transported and something comes under the machine.
      Hans
      “ Sent from my Intel 80286 using MS-DOS 2.0
      https://www.copytechnet.com/images/smilies/biggrin.png
      • zaza
        MECANOGRAPHE
        • Mar 2008
        • 1095
        Re: Bizhub 163
        yes correctly .....cause if l chose A4 size paper the machine know this size ..but if l put the A3 paper the machine red B5 ....also l clean and controlled the detection contector size paper ..it's good ...any other idea .
          • 22954
          Re: Bizhub 163
          You didn't answer my question. Is it an original size detection issue or a copy paper size detection issue? Do you understand the difference? =^..^=
          • zaza
            MECANOGRAPHE
            • Mar 2008
            • 1095
            Re: Bizhub 163
            it's copy paper size detection issue...this is problems .
