C284e c2557 code
  • tech51
    • 846
    [Error Code] C284e c2557 code
    Went to this machine for this code which it has been occurring off and on for a couple of months.
    The toner is being supplied to the dev unit but the toner bottle never rotates to refill the hopper which eventually completely empties causing the code.
    In service mode when in hopper fill mode the bottle rotates normally.
    Once the hopper is full the machine can be toned up again and runs until the hopper empties.
    So far the machine has had a new toner hopper and print control board but this has not cured the fault.
    Has anyone else experienced this?
  • techmann
    • May 2016
    • 41
    Re: C284e c2557 code
    What about the Development unit? Maybe it is not detecting that it is low on toner?
    • allan
      RTFM!!
      • 5462
      It is detecting low toner thus the C2557 code.
      The code is given if the toner carrier ratio goes out of range.
      Whatever
        • 22999
        Something like this maybe?:
        http://www.copytechnet.com/forums/ko...ing-toner.html
        • EarthKmTech
          Step aside, noob
          • May 2009
          • 2139
          when the sub hopper is empty have a look inside it from the top and make sure the level actuator has not popped off its rear post. Had this MANY times.
          Removal is not required to put it back if you have a suitable thin hook tool
          Every time i've changed a hopper at least one has been detached, even out of the box, it happens in transit. The last one i did all 4 were detached.
          • tech51
            • 846
            Spot on!
            It was exactly as described above.
            I had to split mine to fix it but it did the job.
            Thanks a million Earthkmtech.
