What is nice about the older KM original toners is that the composition is on the side of the box.
I have played with lots of toners before because of a lack of the right stock.
Amazing that almost all the B/W toners is the same thing.
Even the developer.
Like the TN 511, TN 710, and TN 014 seems like the same thing as i have changed the toner between all the models.
Does anyone know if there is a difference in toners between the c451 and c452?
other than a chip?
Kelly
All you have to do with switch the head and you will be fine, or you can switch the chip and cut/break a tab off. I have yet to try this with c654 series yet.
I know that the K toner is different for the c451 than c550/c650 same with c452. I am not sure if the toner itself is different, but keep that in mind.
