my bhc 280 tray no 1 paper detect 16k
  • Syuk
    • Jan 2017
    • 13
    how to back to 4A size back
    16k to A4 back
    profesional tech please teach me
  • rrrohan
    • Sep 2011
    • 1977
    Re: my bhc 280 tray no 1 paper detect 16k
    Like i said in your duplicate post yesterday, make sure no paper stuck behind tray as this will interfere with paper tray size detection
    More specifically on the c280 you may have cracked the black bit of spring loaded plastic, compare it to tge other tray to see if this is the case
    • Syuk
      • Jan 2017
      • 13
      [QUOTE=rrrohan;551339]Like i said in your duplicate post yesterday, make sure no paper stuck behind tray as this will interfere with paper tray size detection
      More specifically on the c280 you may have cracked the black bit of spring loaded plastic, compare it to tge other tray to see if this is the case[/Q
      ok try change that item
      • Syuk
        • Jan 2017
        • 13
        • Synthohol
          Certified Konica Expert
          • 5738
          select tray 1 and select tray settings and see if set to auto or did someone program the tray incorrectly?
          • Syuk
            • Jan 2017
            • 13
            Already settle that problem I Change controler
