Is there a procedure to replace the HDD and MFP board on a KM c308? Couldn't find a replacement procedure in the service manual. It reboots daily and claims to have an internal error
km c308 internal error has occurred
Tags: None
blackcat: Master Of The Obvious =^..^= -
Re: km c308 internal error has occurred
I've done it a long time ago and all I came to say is you can't do both at the same time. I tried once and had to put the old hard drive back in. Once you get the device running with the new board you can then go through the HDD replacement.Comment
