Bizhhub C353 error C-3201
  • aAandy
    • Apr 2012
    • 370
    [Error Code] Bizhhub C353 error C-3201
    Hello all
    fuser motor is rotating, fuser is rotating freely, closing door correctly engages fuser drive mechanism to drive fuser
    fault was intermittent,, client would open/close front door & problem would go away,, got to the point where error code is now constant
    seeing the motor is rotating, i presume either the motor is not outputting the pulse signal, the cable is damaged or the controller board is kaput
    anyone had this set of symptoms before?
    any and all help would be very much appreciated
    thanks in advance
    Andy
  • Synthohol
    Certified Konica Expert
    • 5738
    Re: Bizhhub C353 error C-3201
    just to mention, sometimes its the fuser. the bearings start to get tight and slow the fuser down.
    • aAandy
      • Apr 2012
      • 370
      fuser is rotating freely, though thanks for the tip
      • Synthohol
        • 5738
        when it does turn, is there any clicking or clunking sounds that repeat?
        • Hansoon
          • Sep 2007
          • 3350
          Had it once. Just swapping the fuser unit with my workshop machine cured the problem. Both machines are working OK after that since two years now.
          Hans
          “ Sent from my Intel 80286 using MS-DOS 2.0
          https://www.copytechnet.com/images/smilies/biggrin.png
          • aAandy
            • Apr 2012
            • 370
            none
            when i fire it up with the right door open & the fuser drive interlock not actuated, i get a different error (fuser not rotating) when i engage the fuser drive interlock the fuser turns freely, no noises, no resistance turning the fuser by hand & the fuser drive motor doesn't slow down any
            • aAandy
              • Apr 2012
              • 370
              Hans
              something to try - thanks for the tip
